christian1707
Nov 13, 2011Aspirant
Transmission failed to start - does not work!
Hi guys, Transmission DOES start, until i change the password. I changed the password from "password1" to essentially "password23" in the following:- /Transmission/transtart.sh /Transmission/t...
Litoz
Sep 10, 2013Aspirant
Yes it is, actually just a until a week ago I could change that. The issue is that if your NAS reboots or suffers a power failure when it goes back up it may not start the add-on again (well that was my case can't affirm will be always like that).
To fix it:
Good Luck
To fix it:
- Check you forwarded your port
- Check there is no port conflict with neither the GUI( I changed mine to 9091) and the P2P port.
- Manually add the DNS servers to the NAS config from your ISP
- Somewhere I read Google DNS server was 8.8.8.8 could try to add that as the third DNS
Good Luck
