VMColonel
Aug 30, 2010Aspirant
Transmission Setup on the ReadyNAS NV+/Duo:
Preface: I wasn't able to find this all in one place, and I ran into a few snags here and there (Nothing a quick google wouldn't cure) I assume the x86 installer would be similar, but I don't have...
VMColonel
mdgm wrote: You can login to CIFS/SMB (windows file sharing) as admin and access the addons-config share (it may require a reboot to create this) or open the C volume, open the addons-config folder and edit the relevant files using Notepad++ (don't use ordinary Notepad as it'll stuff up the formatting) on a Windows Machine or you can use TextEdit to edit the file on a Mac.
Thanks, good to know, perhaps I should have just made a general "installing any plug-in" post and forked from there. Is this how most plug-ins work, or do the majority force you to SSH in, or have a web interface?
In all seriousness I had no idea the ReadyNAS was this robust (Impulse buy), but now seeing it in action, I'm thinking I should have picked up an Ultra or something x86 based, I would love to run a VM in there with my vent server, that would pretty much free up this quad-core Phenom that the ReadyNAS has almost replaced. (Except maybe the transcoding)
