VMColonel
Aug 30, 2010Aspirant
Transmission Setup on the ReadyNAS NV+/Duo:
Preface: I wasn't able to find this all in one place, and I ran into a few snags here and there (Nothing a quick google wouldn't cure) I assume the x86 installer would be similar, but I don't have...
mdgm-ntgr
Aug 30, 2010NETGEAR Employee Retired
Most add-ons work this way. If not, you can ask the add-on developer if they'll make the necessary changes. It's not hard to take a look at super-poussin's code for the "addons-config" share and do likewise.
Though the Ultra is not on the HCL for VMWare it should work fine. It runs the same OS as compatible devices and has both NFS and iSCSI.
Performance wise, ReadyNAS Pro > ReadyNAS Ultra 6 > ReadyNAS Ultra 4 > ReadyNAS NVX. The NVX Pioneer and Pro Pioneer lack some features of the business units, but still have NFS and iSCSI (iSCSI is available via an add-on for the Pioneer on 4.2.13 or greater).
Some adventurous types have even run VMs directly on a Pro (this definitely requires a fair bit of SSH work) and is unsupported.
