VMColonel
Aug 30, 2010Aspirant
Transmission Setup on the ReadyNAS NV+/Duo:
Preface: I wasn't able to find this all in one place, and I ran into a few snags here and there (Nothing a quick google wouldn't cure) I assume the x86 installer would be similar, but I don't have...
poddster
Jan 10, 2011Aspirant
For anyone with the same problem that I had... the solution was the change the Security Mode in Frontview from Share to User, update the settings.json file, then change the Security Mode back to Share.
