VMColonel
Aug 30, 2010Aspirant
Transmission Setup on the ReadyNAS NV+/Duo:
Preface: I wasn't able to find this all in one place, and I ran into a few snags here and there (Nothing a quick google wouldn't cure) I assume the x86 installer would be similar, but I don't have...
dhodgin
Jan 11, 2011Aspirant
I have a similar problem as above i can install and startup the addon just fine and it works perfectly.
As soon as i shut it down once and change the settings.json file and the startup and shutdown files to modify the default password i can no longer start the service. it says it starts it and then after 3-5 seconds the light turns off on the installed addons page of frontview and launching the transmission web interface just gives a server not found error. the services wont restart once i change those 3 files.
I am editing them in visual studio so maybe its a encoding issue on the text files after resaving?
------------- update
i was editing my files in visual studio and it was resaving the files in a different codepage.
using notepad++ to edit the files preserved ANSI encoding and i can start and stop the service repeatedly now
it must cause it to crash on boot if the files arent encoded as ANSI
