VMColonel
Aug 30, 2010Aspirant
Transmission Setup on the ReadyNAS NV+/Duo:
Preface: I wasn't able to find this all in one place, and I ran into a few snags here and there (Nothing a quick google wouldn't cure) I assume the x86 installer would be similar, but I don't have...
BikeHelmet
Apr 05, 2012Aspirant
martinb wrote: Maybe because I'm not clever enough. I cannot follow the terminalogy here. What is a "putty" for instance... I could handle the bittorrent client and the grease monkey set up, but here I'm lost it seems....
http://www.chiark.greenend.org.uk/~sgtatham/putty/
Used to gain cmdline access to your NAS or other devices.
martinb wrote: I just cannot connect to the transmission interface. Probably some very fundamental thing. Isn't there a transmission-setup-for-dummies? Why can it connect?
What address are you going to? Have you checked the Frontview to verify the service is running? (Green dot)
http://[NAS-IP]:8181/transmission/web/
