VMColonel
Aug 30, 2010Aspirant
Transmission Setup on the ReadyNAS NV+/Duo:
Preface: I wasn't able to find this all in one place, and I ran into a few snags here and there (Nothing a quick google wouldn't cure) I assume the x86 installer would be similar, but I don't have...
martinb1
Apr 07, 2012Aspirant
Thanks for reply! Now it is finally running. It was probably due to that I was using the wrong format when I was saving settings.json in notepad++. But it is not downloading?! I'm forwarding port on my router (internal and external set to the same value, no DMZ activated) and the transmission interface says "port is closed". According to canyouseeme.org the port is open, but not according to the transmission interface. And there is no downloading at all. I just have a clean modem---> router --> ReadyNas NV+. Would be very thankful for help in this matter.
