voidness
Jan 04, 2016Guide
Trasmission stopped working ReadyNAS 104 firmware 6.4.0
All of the sudden my Transmission stopped working checking chkconfig, transmission isn't enable so I tried to but still getting error. root@nas:~# chkconfig transmission on insserv: Service netw...
- Jan 05, 2016
I reinstalled the same firmware and reinstall transmission throught the apps page and everything is fine now. Thanks heaps for you help. This can be closed
mdgm-ntgr
Jan 04, 2016NETGEAR Employee Retired
Which version of the app are you using?
voidness
Jan 04, 2016Guide
I am running 2.82-1
apt-get install transmission=2.82-1
- mdgm-ntgrJan 04, 2016NETGEAR Employee Retired
So you installed it that way rather than using the app from apps.readynas.com ?
Can you send in your logs (see the Sending Logs link in my sig)?
Do you have a backup of your data?- voidnessJan 04, 2016Guide
I have managed to download the log zip, however there are many logs in the zip that I do not wish to share, can you tell me which one you are interested in so I can send that one ?
I dont have a backup of my data unfortunately. With regarding to this error.
"insserv: Service networking has to be enabled to start service transmission-daemon"
do you know what service networking is it referring to ? i cant seem to find it
- voidnessJan 05, 2016Guide
