cybermandeepsin
Mar 17, 2013Follower
Unable to view jpg from ipad
On the ipad I have the RN Remote app and can successfully connect to the Nas and view the files. I am unable to view jpg files or even download them to the ipad. Is there anything I need to do, in order to view the files?
Thanks in advance.
Thanks in advance.
- Mace_WindooAspirantHi Cygenerator,
We have identified the issue with the iPAD controls on the remote App. We are now working on a fix for that particular issue. Also, there will be some changes to the readyDLNA App too.
Thank you for your patients on this - cygeneratorAspirantWow, cool! That's great! :D
Is this problem difficult to fix? I mean: what do you think how long you will approximately need take to get the fix or a workaround (days or weeks)? - Mace_WindooAspirantIt takes time to get things up the the app store.
With the issue you are experiencing (readynas remote), is the behaviour different when holding the device in Landscape? - cygeneratorAspirantWhat the... it's unbelievable! I started readyNAS remote, turned the iPad in the landscape mode and ***boom*** the preview of a pdf file is possible! Suddenly the download of a pdf file is also available. Furthermore,the preview/download of a jpg file is no problem any more! :D :D :D
How cool is that? With this I have a nice little workaround that will make me patient while waiting for an update of the app. 8)
With this knowledge I also tried to get readyDLNS to work - unfortunately without success. In this case the problem is obviously different to the readyNAS remote app.
Concerning the app store: does it mean that the readyNAS remote app will be fixed in the next update? - Mace_WindooAspirantYes, we are working on a fix for the problem as a high priority. The next update will include it. As you can see the problem just effects the controls themselves. I'm glad to here that landscape mode works for you as it confirms the issue you have with remote is the one we are working on.
I'll update this post when the fix is available. - Mace_WindooAspirantThe new version of ReadyNAS Remote is up on the store. Please install it and let me know if it solves the issue for you
- chirpaLuminary
I guess this 'fix' is included in this vague changelog?Mace Windoo wrote: The new version of ReadyNAS Remote is up on the store. Please install it and let me know if it solves the issue for you Some bugs fixed - Mace_WindooAspirantCygenerator,
Can you please try the latest app from the App store and let me know how it goes?
