MarcusRaif
Jan 13, 2021Aspirant
Upgrade my ReadyNas Ultra 6 Plus Model: RNDP600U firmware
I an trying to find out what version of firmware will run on my ReadyNas Ultra 6 Plus Model: RNDP600U Serial: 2H110ARW000AD Purchased: 2011-02-26 firmware: RAIDiator 4.2.17
- Jan 13, 2021
The most recent supported firmware for your NAS is 4.2.31. https://kb.netgear.com/000038793/RAIDiator-x86-Version-4-2-31
However, it can be converted to run OS-6 firmware. Netgear doesn't support that setup, and I do suggest that you increase the RAM in your NAS to 2 GB if you choose to convert it. One benefit of converting to OS-6 is that you'd get support for SMB 3.
Jan 13, 2021Guru - Experienced User
- MarcusRaifJan 13, 2021Aspirant
Is there a manual for firmware 4.2.31?
- mdgmJan 13, 2021Virtuoso
I think the latest manual is for 4.2.17. There wasn't much in the way of new features after 4.2.17, mainly bug fixes and security updates.
