michelefaccini
Sep 07, 2011Aspirant
utorrent 1.8
Hi,I installed the add-on and launched it from the FrontView...I have the page with 'Loading....' that's all....I tried also to configure the utserver file,determining so the utorrent folder and so on...
michelefaccini
I supposed unlike a utorrent windows installation,where the port setting and so on are set up in automatic,in this case this has to be done manually ? My question is simple : after the add-on installation, is it normal not to be able to access to the gui (without any utserver configuration settings) ? The page which comes out is 'Loading....' is there anybody out there ?
- Mar 10, 2018Retired_Member
