super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
sphardy1
Oct 07, 2010Apprentice
losgatos_mark wrote: The username and password were reset to the default upon adding a torrent.
Possible user error? Here's how my settings look and I've changed the password successfully:
All settings get saved in /usr/local/utorrent/settings.dat - you can check permissions just in case; should be owned by "nobody:nogroup"
- Mar 10, 2018Retired_Member
