super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
chhumper
Dec 08, 2010Aspirant
yup. probably right. thank you! would it have worked with Transmission, though? does that support https trackers?
also, a semi-unrelated question: utorrent for the readynas seems to allow me the option of entering proxy information. is there any reason why this would not work as it does with a windows utorrent versions?
thanks, yomark. very much appreciate the reply.
- Mar 10, 2018Retired_Member
