super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
yomark
Dec 14, 2010Aspirant
Hey dhonar, just use the gui to set the paths, that should work.
Set it to something like this:
/c/media means your Media share you have by default on you readynas.
I don't know why the utserver.conf is there, but it seems that it doesn't use the config file at all, so just ignore that file. :)
The logfile present does however work.
