super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
dhonar
Dec 15, 2010Aspirant
Hey Yomark,
Thanks for the quick reply and especially the printscreen. This has solved the problem. Easy doing and setup and it started working in minutes :D torrents are automatically started and all files are stored in the defined folders.
Dhonar
Dhonar
- Mar 10, 2018Retired_Member
