super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
bobbymask
Jan 03, 2011Aspirant
super-poussin wrote:
ShortyMac wrote: I'm trying to install uTorrent on my NVX Pioneer, but it keeps getting stuck on the busy spinner once I hit the install button. Can anyone help me on this problem? Thanks.
*EDIT* Nevermind the install never prompted if it completed or not. uTorrent showed up after I rebooted (busy indicator still spinning). So far, looks like its working great! Configured it based off my Win7 version's settings, tested out a small torrent, and it worked like a charm! Great job and thanks!
I saw same problem for spinner, I'm investigating : no need to reboot do a ctrl+F5
I downloaded Pro-uTorrent_1.8bin, installed by the Frontview of a ReadyNAS Ultra 2, in the "Services/add-ons" section the checked box uTorrent P2P Server is on but as I click "Launch it" the browser page shows a busy spinner as, I understand, described by ShortyMac I quote herein.
Tried ctrl+F5, then reboot, I let the spinner spinning all night long ... nothing (except for a Vista jam I solved going back to a previous recovery point, I installed several adds-on on the brand new NAS, I got my SqueezeBox Duet wonderfully working with my 250 Gb music library filed on the ReadyNas, and it is still happily working at full speed ... I am very happy as I'm not very confortable with all this stuff at the beginning)
Thanks on advance for your help, I see the best opinions are about uTorrent and I'd like to search a solution before choosing another P2P program.
Roberto
