super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
fert
Feb 06, 2011Aspirant
Having no trouble getting 1.9 installed and the UI to come up. I had to do some fiddling with folder permissions to get uTorrent to be able to accept the .torrent files ( setting folders sticky and giving everything nobody:nogroup access).
However, my torrents are simply not downloading. They show up in the UI but are stuck at 0% with a ETA of infinity. Not sure what is wrong here any ideas?
*Edit - looks like this is an issue with a private tracker I am a member of, will see if I can figure it out, other torrents seem to work fine.
- Mar 10, 2018Retired_Member
