super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
chhumper
Feb 07, 2011Aspirant
so, a silly question: if i downloaded files without setting directories using the gui, where would they go by default? i can't seem to locate them.
when i tried to go in and set directory paths, they would disappear after i clicked apply and then ok-ed out. when i next entered the settings, they would no longer be there. using the screenshot above, i set the paths to c/media/... i wrote in the path names for existing folders already setup in the bittorrent folder within media.
i'm sure i'm missing something incredibly obvious. any help would be appreciated.
thank you.
thank you.
- Mar 10, 2018Retired_Member
