super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
alessio_71
Apr 06, 2011Aspirant
super-poussin wrote: go back to 2.0.00 , libc6 must be upgraded to 2.11 and i'm not sure it will not break things in raidiator, will continue testing on my unit
Thank you very much for your answer.
How do you update libc6 to 2.11 that from the standard repository is not available?
Meanwhile I've followed a suggestion from the uTorrent forum and compiled the libc6 2.11 in a different directory and typing:
/usr/local/utorrent/libs/lib/ld-2.11.so --library-path /usr/local/utorrent/libs/lib /usr/local/utorrent/utserver -configfile /usr/local/utorrent/utserver.conf
I managed to start the new uTorrent but I don't know hot to integrate all that row in the /etc/frontview/addons/bin/UTORRENT/start.sh
I think I'll wait for an update from you.
Alex
- Mar 10, 2018Retired_Member
