super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
Retired_Member
Aug 12, 2011Wish I'd found this post before trying to install this add-on.
My NVX is now stuck at "Booting...Installing addon"
Does anyone know how to fix this?
Have tried reinstalling firmware, but that made no difference.
It seems a 'jedi' fixed the other person's problem. Do you know what they will have done?
I'm guessing you have to telnet into the device using Putty, then...?
- Mar 10, 2018Retired_Member
