super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
baygacon
Oct 21, 2011Aspirant
lightbulb wrote: Question for S-P probably, but anyone else please add your 2c.
PRO6 with 4.2.19.
No previous uT install.
Installed 2.2.02 right off the bat, but would not start (libc6 issue)
uninstalled and then Uploaded 2.0.0 and all looked good at first glance, infact 8gb torrents came down overnight before i noticed this issue:
My /c/media was shared as 'media' prior to uT install, offering folders such as Pictures, Video, Music etc.
After install my 'media' share was hijacked and offered the sub-folder 'utorrent' out of the media share (nothing else). This contained the utorrent from the addons config folder. I uninstalled uT 2.0.0 but did not get my old share structure back, so i renamed my media share to 'mediax' in frontview, and renamed it back to 'media' and i got my correct /c/media/ structure back.
Only thing I changed in webui was the torrent storage paths, actually to /c/media/BitTorrent/xxxx
==so perhaps the uT install messes with the share settings when a 'media' share is already existing??==
Could you help to clarify above S-P?
this is a known issue and will be resolved in 4.2.20 (apparently). I'm hanging off until this firmware update before installing any addons for this reason.
