super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
gibxxi
Oct 22, 2011Guide
dsm1212 wrote: Not sure why no one is responding to you Trial_Master. I'm not using utorrent because of the lack of an ip blocker, but I know utorrent is not open source so what you are getting must be a linux binary provided by the the utorrent site. Just go to the utorrent web site and look up that version to read about it or ask your question there.
steve
If you mean ipfilter, then uTorrent server supports this. See advanced settings tab in the configuration options to enable it. Also, you can add your own ipfilter.dat file to the install by copying the file to the following folder on the NAS (root access required):
/usr/local/utorrent
I believe if the "enable ipfilter" option is enabled, utorrent automatically downloads the file from somewhere, so i've disabled the option for the time being, lest it overwrite my custom ipfilter.dat file.
- Mar 10, 2018Retired_Member
