super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
Retired_Member
Feb 01, 2012
dsm1212 wrote: I did manage to get utorrent 3.0 running on 4.2.19.
Steve, thanks for your post which I have begun following. I have a few questions:
1. Are this...
dsm1212 wrote: There is a 64 bit version of utorrent 3.0 for linux posted here: http://forum.utorrent.com/viewtopic.php?id=102110
...and these:
dsm1212 wrote: #finally replace the utorrent binary and ui with the new ones
#install the latest addon in this forum if you haven't already....
The webui.zip from https://forum.utorrent.com/viewtopic.php?id=58156
...the same as SuperPoussin's 2.022 release?
2. Is there a quicker/easier way to get these?:
- I'm 47 minutes into the extraction and still on folders beginning with "d".
dsm1212 wrote:
# Build 64 bit ssl shared libs
Download the big netgear GPL source archive for 4.2.19 and extract the openssl directory.
3. Do we still need to do the glibc thing referred to in the post 2 above yours?
4. Finally, what is the correct url / port to get the web gui running? The launch button on the addon doesn't work on my v2.2.02 NVX installation.
- Mar 10, 2018Retired_Member
