super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
Retired_Member
Feb 01, 2012
tribal wrote: ... I had to force install the newest dpkg to take out the breaks I was getting when trying to install libc6.
Hi - how did you do that?
I tried: apt-get -f install as suggested by the error message:
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libc6: Depends: libc-bin (= 2.11.3-2) but it is not going to be installed
libc6-amd64: Depends: libc6 (= 2.7-18lenny7) but 2.11.3-2 is to be installed
libc6-dev: Depends: libc6 (= 2.7-18lenny7) but 2.11.3-2 is to be installed
locales: Depends: glibc-2.7-1
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
But it still says:
package uses Breaks; not supported in this dpkg
dpkg: error processing /var/cache/apt/archives/libc6_2.11.3-2_i386.deb (--unpack ):
unsupported dependency problem - not installing libc6
Errors were encountered while processing:
/var/cache/apt/archives/libc-bin_2.11.3-2_i386.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
- Mar 10, 2018Retired_Member
