super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
Retired_Member
Feb 01, 2012So I tried manually downloading libc6_2.11.3-2_i386.deb from http://packages.debian.org/squeeze/i386/libc6/download and installing it using:
But still got an error:
Rebooted but launch button still fails to launch the interface.
As you can tell I'm floundering here. can anyone tell me if there is a way to reach uTorrent on the NAS remotely, like Transmission Remote?
dpkg -i --force-depends libc6_2.11.3-2_i386.deb
Can't exec "locale": No such file or directory at /usr/share/perl5/Debconf/Encoding.pm line 16.
Use of uninitialized value in scalar chomp at /usr/share/perl5/Debconf/Encoding.pm line 17.
/var/lib/dpkg/info/libc6.postinst: line 300: ldconfig: command not found
dpkg: error processing libc6 (--install):
subprocess post-installation script returned error exit status 127
- Mar 10, 2018Retired_Member
