super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
Retired_Member
Feb 06, 2012Steve, thanks for your reply
ldd utserver produces this for me:
ldd: exited with unknown exit code (126)
and ps -ef | grep utserver returns this:
root 23447 22411 0 09:10 pts/0 00:00:00 grep utserver
I'm confused - in your post above, where you say:
dsm1212 wrote: 1. Those are not the same as what is in SuperPoussin's kit. New 32 bit utorrents require the new glibc which is a problem. The ones I pointed to are 64 bit builds that happen to use the older libraries and don't require the new glibc.
....which one do you mean - a 64bit version from somewhere else, or S-P's 32 bit version?
dsm1212 wrote: #install the latest addon in this forum if you haven't already.
I think I did install the update in the end - using the forced method, mentioned above. How can I revert back to the old one?
dsm1212 wrote: 3. No you don't need to do the glibc update. I think that would be dangerous. Hopefully you didn't get very far :-).
- Mar 10, 2018Retired_Member
