super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
dsm1212
Feb 06, 2012Apprentice
Ah, Ok, I see the confusion. I was just using the super-poussin addon to get the user interface and stop/start configuration. The rest of the steps are to get a utserver executable that will actually run because the one in the latest super-poussin addon won't work with the older glibc.
Your ldd error is very strange. I'm a little worried for you that the libc change you attempted may be a problem because I think ldd comes with glibc. You can probably live without ldd, but it doesn't bode well. I'm not sure how to undo what was suggested by someone else for glibc. What do you get when you try to run utserver?
cd /usr/local/utorrent
./utserver
You'll have to ctrl-c out if it starts, but it probably won't since it doesn't work for you from the web ui.
steve
./utserver
steve
- Mar 10, 2018Retired_Member
