super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
dsm1212
Feb 07, 2012Apprentice
Just do:
apt-get remove lib64gcc1
apt-get remove libc6-dev-amd64
and delete the other files you built manually.
I can't speak to the glibc stuff.
At that point you should probably remove the utorrent addon through the web UI and install one of S-P's older versions.
steve
steve
- Mar 10, 2018Retired_Member
