super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
Retired_Member
Feb 07, 2012
dsm1212 wrote: Just do:
apt-get remove lib64gcc1
I get this:
Reading package lists... Done
Building dependency tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
binutils: Depends: libc6 (>= 2.11) but 2.7-18lenny7 is to be installed
Depends: libstdc++6 (>= 4.4.0) but 4.3.2-1.1 is to be installed
libc-dev-bin: Depends: libc6 (> 2.11) but 2.7-18lenny7 is to be installed
libc6-dev: Depends: libc6 (= 2.11.3-2) but 2.7-18lenny7 is to be installed
libc6-dev-amd64: Depends: libc6-amd64 (= 2.11.3-2) but 2.7-18lenny7 is to be i nstalled
W: Couldn't stat source package list http://www.readynas.com 4.2.19/ Packages (/ var/lib/apt/lists/www.readynas.com_packages_4.2.19_Packages) - stat (2 No such f ile or directory)
W: Couldn't stat source package list http://archive.debian.org etch/main Package s (/var/lib/apt/lists/archive.debian.org_debian_dists_etch_main_binary-i386_Pack ages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a s olution).
and something similar for the other command. I'm guessing that means it didn't work?
dsm1212 wrote: and delete the other files you built manually.
Could you remind me where I should look for those? Thanks
- Mar 10, 2018Retired_Member
