super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
dsm1212
Feb 07, 2012Apprentice
I think this is due to making changes to the apt sources.list when you did the glibc install. I'm really wary of what to suggest to you about the glibc changes. The two 64 bit packages and two 64 bit libraries I had you install are harmless since your machine can't use them so at this point don't try to force install them just let them be. I'd focus on figuring out how to undo the glibc changes, then set your sources.list back and then, if you really want to, you can remove the packages I listed. Removing glibc could be dangerous if you end up left without something critical so be careful. Make sure you have your important files backed up before you try it.
You should have a directory tree where you built openssl to delete.
steve
steve
- Mar 10, 2018Retired_Member
