super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
geoffnordling
Mar 16, 2012Aspirant
Hi Guys,
I got an issue i don't know how to resolve, I am running utorrent 2.0.0 ( only one I could get to work) and I cannot specify folders to use and I can't find where it is downloading the files to. the log states "Can't use same folder (/usr/local/utorrent) for both autoload and torrent storage" I am trying to set it to folders I created in my Media share so I am filling the directory with say for eg. [/c/media/utorrent/incomplete]. but it will not save it in the GUI? I am running a RNDU6000 with 3x2TB drives. It was working for ages but then I restarted the NAS and given I was running 4.2.19 My shares went all hinky and I had to rename them to refresh it. This normally works but for some reason this time instead of renaming the share it created a folder in the share with the new name and dumped everything in to it except the uTorrent folder, I believe this was a result of renaming the share while uTorrnet was running... My bad. Now I backed up all my data to my PC and then did a factory reset on the NAS, updated it to 4.2.20 T40 as that is supposed to fix the add-ons breaking the shares and now utorrent (freashly installed) will not accept my directories?
Help? I have to DL my torrents with my 800w consuming Gaming PC till I get this fixed. :roll:
- Mar 10, 2018Retired_Member
