super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
Dewdman42
May 25, 2012Virtuoso
Thanks for providing the link to the 2.0.0 bin. does anyone know which actual version of utserver that is? The newest version I have been able to get working on my Ultra2+ has been Beta 3.0-24118, but I was not able to use an addon bin directly.
If this 2.0.0 bin is at least that new, then I will use it.
Below are the steps I did in order to get 3.0-24118 working on my Ultra2+. I would like to know which version is in this 2.0.0 bin, but looking at the docs it provided, it appears to be slightly older. If anyone knows a version newer than 24118 that will run on the ultra2+ using the older libc, please let us know. That is the newest one I could fine.
- First grab the older debian pkg from here: http://www.sitedesign.hu/utorrent/ (the latest 25053 release won't work on ultra2)
- unpack the .deb file with dpkg. The only file you need is "utserver".
- Install any of the utorrent addons. I used 2.2.01. It makes no difference which ones. Don't try to start it yet.
- Download the latest webui file from here: https://sites.google.com/site/ultimasites/files/utorrent-webui.2012050518174554.zip?attredirects=0&d=1. If you know of a newer one, please let us know, but that appears to be the newest one.
- Copy the webui file and rename it to '/usr/local/utorrent/webui.zip'
- Copy the file 'utserver' which you extracted from the deb archive above, over the top of the binary provided from the addon. That is located at '/usr/local/utorrent/utserver'.
- Edit the utorrent config file to get started. Once you start the gui the first time you should immediately go to settings and adjust all the settings(see notes below). That file is located at '/c/addons-config/utorrent/utserver.conf'
- Start utorrent from Frontview
- to view the utorrent gui, go to http://<readynas>:<port>/gui/
So here was my utserver.conf file in order to get started:
token_auth_enable: true
admin_name: admin
admin_password: password
ut_webui_port: 8080
ut_webui_dir: /usr/local/utorrent/
dir_active: /c/raid/Downloads/utorrent/partial/
dir_completed: /c/raid/Downloads/
dir_torrent_files: /c/raid/Downloads/utorrent/torrents/
Once you have the gui up, go into settings immediately and set all the rest of your settings. Note, I have heard that there might be some memory leaks or such if you don't provide all the directories in there.
dsm also has a post earlier in this thread about how to make the newest 64bit version of utserver run on the ultra2, but it involves installing some libraries, I decided to stick with this one. see his post here: http://www.readynas.com/forum/viewtopic.php?f=36&t=45059&start=180#p335347
- Mar 10, 2018Retired_Member
