super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P Utorrent for x86 2.2.01 Utorrent for x86 2.0.00 Utorrent for x86 1.8.0 Super-Poussin changes: Now you can access logs in /c/addons-config/utorrent/ :) Now...
sup3rm4n
Jul 09, 2012Aspirant
DSM, I stepped in to a problem on the way.
# Build 64 bit ssl shared libs
Download the big netgear GPL source archive for 4.2.19 and extract the openssl directory.
cd to the openssl directory
chmod +x util/*.sh
./config shared
make
make test
make install
This part gave out error after ./config shared
First not permision, changed directory permissions, then error "sh: make: command not found" at ./config shared.
Have any idea?
chmod +x util/*.sh
./config shared
make
make test
make install
Have any idea?
- Mar 10, 2018Retired_Member
