super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P
Utorrent for x86 2.2.01
Utorrent for x86 2.0.00
Utorrent for x86 1.8.0
- Super-Poussin changes:
- Now you can access logs in /c/addons-config/utorrent/ :)
- Now you can acces documentation in /c/addons-config/utorrent/docs
- Now you can edit configuration in /c/addons-config/utorrent/utserver.conf (Use interface it's more easy, and do not forget to stop utorrent before doing changes
•HTTPS trackers are unsupportedVersion 3.0 alpha (build 22789)
- Added fields to the About box in the web UI to present the external IP address and UDP/TCP ports assigned by a UPnP router to the server
- Added speculative fix for crash on POSIX platforms occurring when any configurable directories (e.g., active, completed, temporary, autoload, request) contain Unicode characters
- Fixed documentation by changing feed_id to feed-id in two places
µTorrent Server 3.0 alpha build 22708 (for Linux)
- Added daemon argument which directs the server to run in its own
process group- Added usage argument which directs the server to display the set of
valid command-line arguments before exiting - server also prints error
and usage messages before exiting if it detects at least one
unrecognized command-line argument- Added settings finish_cmd and state_cmd to provide a way to invoke
asynchronous processes for torrent lifecycle events- The add torrent dialog in the web UI now allows the user to choose
which download directory to use for the torrent being added- Correct JSON output is now generated for the list-dirs action request
- The name of the directory created by extracting the product archive now
includes utorrent instead of bittorrent- Removed ul_slots_per_torrent setting since it no longer has a function
- Added ut_webui_dir setting in the configuration file, which specifies
the directory containing the webui.zip archive or the unarchived files
to be served for the web UI- Added pidfile argument which permits the specification of a file to be
created by the utserver process which will contain the ID of the
utserver process- Added logmask setting in the configuration file which permits logging
to be configured (and subsequently modified as part of handling a
hangup signal), and removed support for LOGMASK environment variable- The server rereads the configuration file upon receipt of a hangup
signal or when creating or moving a file named rcf.utmr in the
dir_request directory - see the cautions in the user manual about
sending a hangup signal when attempting to change the value of
dir_request- Added settings admin_name and admin_password to allow administrators to
define initial non-default credentials for authenticating to the server
via the HTTP interface- Fixed documentation by changing filter_id to filter-id in one place
- 2010-09-13: Version 3.0 alpha (build 21886)
- Ensure alternative listening port setting persists when changed via web
UI
- Include changes list in docs directory of product archive
- Add mention of configfile and settingspath command-line arguments,
rearrange content of Getting Started section of user manual
- Support configfile argument to specify configuration file location
- Disable BEP22 DNS support on POSIX platforms
- Include plain text version of the user manual in docs directory of
product archive
- Include a EULA file in the docs directory of the archive
- Change default log file for logfile argument to utserver.log
- Fix documentation error saying to use forward slash (/) to precede a
command-line argument keyword - should use a dash (-) on POSIX systems
1.2 solve installation issue and some start issue
gui is on port 8080
user is admin without password
please configure it before adding torrent (where to save files .... (/c/media/BitTorrent/ is a good choice))
also enable ipfilter.dat in advanced option (the addon update ipfilter.dat each day)
- Trial_MasterAspirantThat did it, cheers....
super-poussin wrote: sounds like it supports rss feed , if you have an example I can try
Where are the RSS feed settings? - sphardy1ApprenticeActually - I think that is a capability of the Windows version.
The mac/linux utorrent client doesn't have all of the features of the windows version (yet) - at least, not in the UI.
Update: Did a little more checking. The uTorrent team seem to be working on adding RSS support. Definately there are suggestions it is being worked on for the mac version as it is a key feature request, and it appears the linux core may have some support there (no big surprise as I would suspect the linux and mac cores to be very closely related). But equally important for us NAS users, the webui interface does not have support for RSS feeds yet. Check here: http://www.utorrent.com/ideabank and you will see it is one of the requests from other users in their "ideabank" feature request mechanism (check the mac and webui sections). - super_poussinVirtuosoyep there's rss settings in advanced tab but try to add an rss feed did not work for me using http:// will try with rss:
- Trial_MasterAspirantI only see rss.feed_as_default_label, rss.smart_repack_filter and rss.update_interval. Where are you trying to enter the rss reed?
sphardy wrote: Actually - I think that is a capability of the Windows version.
Thanks for a really detailed post on the rss capabilities :) - lappen71AspirantSo it´s impossible to make utorrent work on a ReadyNAS NX+?
Because i have big problem with the built in torrent and i dont like Transmission that very much. - sphardy1Apprentice
lappen71 wrote: So it´s impossible to make utorrent work on a ReadyNAS NX+?
Assuming you mean the NV+, then you are correct - lappen71AspirantOf course i mean NV+ :)
That was very bad news.
But why?. Because of hardware? - abemanAspirantHi
I downloaded the 1.1 version from this topic and installed it.
The install never finished but when I refreshed the frontview page it did show up fine.
However, when I rebooted the device some time later it got stuck at:
Booting...
Spinning Down...
I have posted all the details here:
http://www.readynas.com/forum/viewtopic.php?f=64&t=45100
I have tried os reinstall but that does not help same thing happens,
it just goes to installing addon and then the spinning down message
I have contact netgear support but they do not want to do anything as
the addon is from the community and therefore non official
Anyone have any ideas?
Bram
- Mar 10, 2018Retired_Member
