super_poussin
Sep 03, 2010Virtuoso
utorrent for X86 2.2.01
Tested on Ultra and Pro :P
Utorrent for x86 2.2.01
Utorrent for x86 2.0.00
Utorrent for x86 1.8.0
- Super-Poussin changes:
- Now you can access logs in /c/addons-config/utorrent/ :)
- Now you can acces documentation in /c/addons-config/utorrent/docs
- Now you can edit configuration in /c/addons-config/utorrent/utserver.conf (Use interface it's more easy, and do not forget to stop utorrent before doing changes
•HTTPS trackers are unsupportedVersion 3.0 alpha (build 22789)
- Added fields to the About box in the web UI to present the external IP address and UDP/TCP ports assigned by a UPnP router to the server
- Added speculative fix for crash on POSIX platforms occurring when any configurable directories (e.g., active, completed, temporary, autoload, request) contain Unicode characters
- Fixed documentation by changing feed_id to feed-id in two places
µTorrent Server 3.0 alpha build 22708 (for Linux)
- Added daemon argument which directs the server to run in its own
process group- Added usage argument which directs the server to display the set of
valid command-line arguments before exiting - server also prints error
and usage messages before exiting if it detects at least one
unrecognized command-line argument- Added settings finish_cmd and state_cmd to provide a way to invoke
asynchronous processes for torrent lifecycle events- The add torrent dialog in the web UI now allows the user to choose
which download directory to use for the torrent being added- Correct JSON output is now generated for the list-dirs action request
- The name of the directory created by extracting the product archive now
includes utorrent instead of bittorrent- Removed ul_slots_per_torrent setting since it no longer has a function
- Added ut_webui_dir setting in the configuration file, which specifies
the directory containing the webui.zip archive or the unarchived files
to be served for the web UI- Added pidfile argument which permits the specification of a file to be
created by the utserver process which will contain the ID of the
utserver process- Added logmask setting in the configuration file which permits logging
to be configured (and subsequently modified as part of handling a
hangup signal), and removed support for LOGMASK environment variable- The server rereads the configuration file upon receipt of a hangup
signal or when creating or moving a file named rcf.utmr in the
dir_request directory - see the cautions in the user manual about
sending a hangup signal when attempting to change the value of
dir_request- Added settings admin_name and admin_password to allow administrators to
define initial non-default credentials for authenticating to the server
via the HTTP interface- Fixed documentation by changing filter_id to filter-id in one place
- 2010-09-13: Version 3.0 alpha (build 21886)
- Ensure alternative listening port setting persists when changed via web
UI
- Include changes list in docs directory of product archive
- Add mention of configfile and settingspath command-line arguments,
rearrange content of Getting Started section of user manual
- Support configfile argument to specify configuration file location
- Disable BEP22 DNS support on POSIX platforms
- Include plain text version of the user manual in docs directory of
product archive
- Include a EULA file in the docs directory of the archive
- Change default log file for logfile argument to utserver.log
- Fix documentation error saying to use forward slash (/) to precede a
command-line argument keyword - should use a dash (-) on POSIX systems
1.2 solve installation issue and some start issue
gui is on port 8080
user is admin without password
please configure it before adding torrent (where to save files .... (/c/media/BitTorrent/ is a good choice))
also enable ipfilter.dat in advanced option (the addon update ipfilter.dat each day)
- super_poussinVirtuosotry 2.2.02
- ranko1AspirantJust updated to 2.2.02 and I cant get utorrent to work either:
Holybell:/usr/local/utorrent# ./utserver --help
./utserver: /lib/libc.so.6: version `GLIBC_2.11' not found (required by ./utserver)
Using RAIDiator 4.2.17 - super_poussinVirtuoso
ranko wrote: Just updated to 2.2.02 and I cant get utorrent to work either: Holybell:/usr/local/utorrent# ./utserver --help
what does ldd utserver provide ?
can you also provide me a uname -a ? - ranko1Aspirant
super-poussin wrote: ranko wrote: Just updated to 2.2.02 and I cant get utorrent to work either: Holybell:/usr/local/utorrent# ./utserver --help
uname -aHolybell:/usr/local/utorrent# uname -a
Linux Holybell 2.6.37.5.RNx86_64.2.1 #1 SMP Tue Mar 29 16:38:58 PDT 2011 x86_64 GNU/Linux
LDD Info:Holybell:/usr/local/utorrent# ldd utserver ./utserver: /lib/libc.so.6: version `GLIBC_2.11' not found (required by ./utserver)
linux-gate.so.1 => (0xffffe000)
libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xf7793000)
libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xf7640000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf7627000)
libm.so.6 => /lib/libm.so.6 (0xf7601000)
librt.so.1 => /lib/librt.so.1 (0xf75f8000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf75eb000)
libc.so.6 => /lib/libc.so.6 (0xf74ad000)
/lib/ld-linux.so.2 (0xf77e1000)
libdl.so.2 => /lib/libdl.so.2 (0xf74a9000)
libz.so.1 => /usr/lib/libz.so.1 (0xf7493000)
EDIT: This is a brand new unit, just shoved in 6 disks and factory reset it. Mods installed: istatd, php, enableroot, htop.
Would prefer to run utorrent, rather than your transmission addon, I find utorrent nicer :) - startideAspirantI tried a quick update, first from frontview, no go, same problem.
Then I tried to add the AddOn again over the existing, no go.
Added the 2.0.00 AddOn again, and it works.
Sorry I forgot to do a LDD when it was installed, but I get the same
error when trying to execute utserver.
root@nas:/usr/local/utorrent# uname -a
Linux nas-medusa 2.6.37.6.RNx86_64.2.1 #1 SMP Mon Aug 15 16:19:41 PDT 2011 x86_64 GNU/Linux
Can try some more tomorrow. - ranko1Aspirantsuper-poussin, any news for us if there is a fix for this uTorrent issue?
I'd love to get it working... :) - OrionosAspirantSame issue here. Fresh Ultra with 4.2.19
2.2.00 works, updating/overwriting with 2.2.01 works. Fresh install of 2.2.01 and update/overwrite or fresh install of 2.2.02 fails.
RDNSAN:~# uname -a
Linux RDNSAN 2.6.37.6.RNx86_64.2.1 #1 SMP Mon Aug 15 16:19:41 PDT 2011 x86_64 GNU/Linux
RDNSAN:~# ldd /usr/local/utorrent/utserver
/usr/local/utorrent/utserver: /lib/libc.so.6: version `GLIBC_2.11' not found (required by /usr/local/utorrent/utserver)
libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xf76e6000)
libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xf758e000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf7575000)
libm.so.6 => /lib/libm.so.6 (0xf754f000)
librt.so.1 => /lib/librt.so.1 (0xf7546000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf7539000)
libc.so.6 => /lib/libc.so.6 (0xf73fb000)
/lib/ld-linux.so.2 (0xf7737000)
libdl.so.2 => /lib/libdl.so.2 (0xf73f7000)
libz.so.1 => /usr/lib/libz.so.1 (0xf73e1000)
This is 2.2.02, I'll post 2.2.00 in a bit. - OrionosAspirant2.0.00
libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xf76e0000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf76c8000)
libm.so.6 => /lib/libm.so.6 (0xf76a1000)
librt.so.1 => /lib/librt.so.1 (0xf7698000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf768b000)
libc.so.6 => /lib/libc.so.6 (0xf754d000)
/lib/ld-linux.so.2 (0xf7731000)
libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xf73f5000)
libdl.so.2 => /lib/libdl.so.2 (0xf73f1000)
libz.so.1 => /usr/lib/libz.so.1 (0xf73db000)
Upgraded to 2.2.01
libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xf777e000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf7766000)
libm.so.6 => /lib/libm.so.6 (0xf773f000)
librt.so.1 => /lib/librt.so.1 (0xf7736000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf7729000)
libc.so.6 => /lib/libc.so.6 (0xf75eb000)
/lib/ld-linux.so.2 (0xf77cf000)
libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xf7493000)
libdl.so.2 => /lib/libdl.so.2 (0xf748f000)
libz.so.1 => /usr/lib/libz.so.1 (0xf7479000)
Clean install 2.2.01
libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xf76fc000)
libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xf75a4000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf758b000)
libm.so.6 => /lib/libm.so.6 (0xf7565000)
librt.so.1 => /lib/librt.so.1 (0xf755c000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf754f000)
libc.so.6 => /lib/libc.so.6 (0xf7411000)
/lib/ld-linux.so.2 (0xf774d000)
libdl.so.2 => /lib/libdl.so.2 (0xf740d000)
libz.so.1 => /usr/lib/libz.so.1 (0xf73f7000)
You know, I have no idea what ldd does...
EDIT: I just found out there was no 2.2.00, just 2.0.00, apologies... - ranko1AspirantAnyone able to provide a uTorrent 2.2.0 install (download) the link for it on Page 1 now gives a 404.
Thanks,
- Mar 10, 2018Retired_Member
