jg167
Sep 19, 2012Aspirant
10.8.2 MIGHT have issues, now mostly solved
I'm having time machine problems using the ReadyNAS time machine server on NV+ that worked fine for 10.8.1 . I used the stock ReadyNAS time machine server for 10.8.1 and all was well. I just upgra...
mdgm-ntgr
Sep 19, 2012NETGEAR Employee Retired
Have you tried rebooting the Mac and the NAS?
Have you tried clearing the cache in Safari (Safari > Reset Safari > Make sure "Remove All Website Data" is checked - nothing else needs to be checked - and click Reset)?
Did you do a Combo Update or did you simply update via the App Store?
If you didn't do a Combo Update, you could try that: http://support.apple.com/kb/DL1581
The Combo Update includes both the 10.8.1 and 10.8.2 updates. Sometimes Combo Updates work better.
