youngskywalker
Aug 07, 2014Aspirant
104 backup individual folders from external USB drive?
Hey, i recently purchased a readyNAS 104 without drives. i've put two old 500GB drives in it in a RAID 1 for now, until i can afford bigger drives. i've got 1TB external hard drive which is about 80...
Aug 08, 2014Guru - Experienced User
50 MBs is the write speed over a gigabit network - reads are faster. If you need ~100 MBs write speeds you need an RN314.
You can use the USB port, though you need to get the path correct. I generally don't use it, and am not at the machine right now - and don't want to give you mis-information.
