Obibatk
Jun 18, 2016Aspirant
1MB/s transfer rater on RN104
I only get 1MB/s transfer rate when coping files/folders between my NAS and PC but I get about 24MB/s between a an external USB drive and PC. Can anyone please help me with this. Connection between P...
Anonymous
Jun 18, 2016Please, your connection between PC and router is 1Gbps, not 1GB. It's complicated enough already ;)
Is that happening since a specific event? Did you always have this kind of slow transfer speed? Did you change anything in the config of the NAS recently? Is the GUI responsive or very very slow?
- ObibatkJun 19, 2016Aspirant
I disabled the antivirus a couple of days ago.
The Nasttester_17 gives Iteration of 1.35MB/sec
I have 2 x 2TB drives configured with X-Raid
GUI has become slow also
- StephenBJun 19, 2016Guru - Experienced User
What firmware are you running (also did you recently update it)?
Have you checked the disk health? You can download the logs (zip file) and look at smart_history.log
Hi StephenB, yes I upgraded the firmware about 2 weeks ago to version 6.5.0
Both HDDs are showing as healthy.
