Obibatk
Jun 18, 2016Aspirant
1MB/s transfer rater on RN104
I only get 1MB/s transfer rate when coping files/folders between my NAS and PC but I get about 24MB/s between a an external USB drive and PC. Can anyone please help me with this. Connection between P...
Obibatk
Jun 19, 2016Aspirant
I disabled the antivirus a couple of days ago.
The Nasttester_17 gives Iteration of 1.35MB/sec
I have 2 x 2TB drives configured with X-Raid
GUI has become slow also
Jun 19, 2016Guru - Experienced User
What firmware are you running (also did you recently update it)?
Have you checked the disk health? You can download the logs (zip file) and look at smart_history.log
- ObibatkJun 19, 2016Aspirant
Hi StephenB, yes I upgraded the firmware about 2 weeks ago to version 6.5.0
Both HDDs are showing as healthy.
All the entries in the smart log file is zero for each drive.
- StephenBJun 20, 2016Guru - Experienced User
Did the problem begin right when you updated the firmware, or did it begin later on?
What version of Windows are you running?
Do you have jumbo frames (MTUs larger than 1500) enabled on the NAS and/or the PC?
Does the PC also have a WiFi adapter, or only ethernet?
Is there any internet security software/antivirus software running on the PC?
