euphos
Aug 25, 2014Aspirant
2 quick questions on my RN104 OS6 screens
Okay, 2 (hopefully) quick questions. My System > Performance tab shows all 4 of my drives, temperatures, etc is the status section. The first 3 drive temps look good. However, drive 4 the temp is -1...
Aug 26, 2014Guru - Experienced User
If disk4 has 15448 bad sectors, then it has failed and needs replacement. Anything with more than 50 reallocated sectors should be replaced.
Can you post the SMART stats on these disks?
