euphos
Aug 25, 2014Aspirant
2 quick questions on my RN104 OS6 screens
Okay, 2 (hopefully) quick questions. My System > Performance tab shows all 4 of my drives, temperatures, etc is the status section. The first 3 drive temps look good. However, drive 4 the temp is -1...
vandermerwe
Aug 26, 2014Master
You did not say what the volume page says about your volume. The disk most likely has failed completely as StephenB pointed out.
I would say your situation is not safe, you need to replace the drive.
Make sure you have a backup of data on the Nas.
I think testing outside is reasonable where there is some doubt about the health of a disk. I think here it is fairly clear from your initial problem and the error count that the disk is dead or nearly dead.
