euphos
Aug 25, 2014Aspirant
2 quick questions on my RN104 OS6 screens
Okay, 2 (hopefully) quick questions. My System > Performance tab shows all 4 of my drives, temperatures, etc is the status section. The first 3 drive temps look good. However, drive 4 the temp is -1...
Aug 26, 2014Guru - Experienced User
Yes. And it is important to know the status of the other drives, which is why I requested the SMART stats on all of them.
vandermerwe wrote: I would say your situation is not safe, you need to replace the drive.
I agree that a backup is urgently needed.
On testing, the only reason to test a drive with > 1500 bad sectors is if it is still under warranty and you want to get the failure code for the RMA.
