euphos
Aug 25, 2014Aspirant
2 quick questions on my RN104 OS6 screens
Okay, 2 (hopefully) quick questions. My System > Performance tab shows all 4 of my drives, temperatures, etc is the status section. The first 3 drive temps look good. However, drive 4 the temp is -1...
euphos
Aug 27, 2014Aspirant
Okay, I ended up ordering (2) x ST4000DM000 4TB drives for $315 delivered. I plan to obviously replace the one bad one (/dev/sda in slot #4). Is there another one that should be the next to be replaced? Or do I need to do one in the slot next to the other 4TB drive (ie /dev/sdb in slot#3)? The reason I ask, is the drive in slot #3 was just replaced about a month ago. The "Reallocated Sector Count" is zero for the other three. So all else being equal, I'd think I should replace either of the disks in Slot # 1 or #2 (/dev/sdc or /dev/sdd) with the other 4 TB drive. Will that work and give me ~1TB of extra storage? What's the formula for figuring it out?
As an aside, I believe the drives in Slots #3 & #4 were the ones I recycled from 2 Seagate GoFlex Home 3TB "NAS" units that I wasn't real happy with.
