euphos
Aug 25, 2014Aspirant
2 quick questions on my RN104 OS6 screens
Okay, 2 (hopefully) quick questions. My System > Performance tab shows all 4 of my drives, temperatures, etc is the status section. The first 3 drive temps look good. However, drive 4 the temp is -1...
Aug 27, 2014Guru - Experienced User
seek error rate and raw error rate have vendor-specific formats, which makes it difficult to know what to make of them.
I don't know what's going on with the performance tab data, but since you are replacing the disk anyway I don't think its a concern. If you still see the -1 after the new disk is inserted and synced, then submit a support request on that at support.netgear.com.
