dfp
Aug 14, 2013Aspirant
2100 Expansion Problem 4tb drives x 4
I have a Readynas 2100 with 4x 2tb drives. I have replaced these drives one by one with 4tb drives so I now have 4x4tb drives. I didn't run the expansion until the end, when I rebooted the NAS...
mdgm-ntgr
May 06, 2015NETGEAR Employee Retired
They should work but if you run into issues using disks outside the compatibility list support will be unable to help.
Not all drives are equal. Some are more suited to NAS use than others.
