JerryY
Jan 24, 2015Aspirant
316/516 + DLNA/PLEX questions
I am looking at purchasing either the ReadyNAS 316 or 516 in the near future, and have some questions about the built in DLNA server versus installing the Plex Media Server.
I understand the difference in horsepower available on the units (atom 2.1 GHz vs I3-3220), and that the 516 comes with twice as much ram onboard.
Is there a list of file types supported by the ReadyDLNA program? I already know what the Plex Media Server supports for file types.
Main purpose for either of the NAS's is to provide backup for 8 computers and provide media streaming to various TV's, computers and tablets. From reading at the Plex support site, the 516 supports video transcoding at 720p and up, whereas the 316 may begin to be underpowered at 720p and up. Is this really a big deal? Does the Plex Media Server have better support than ReadyDLNA?
Any information would be greatly appreciated.
Thanks
Jerry
Thanks
Jerry
- mdgm-ntgrNETGEAR Employee RetiredA clean install may be the way forward here unless you can get someone on the Plex forums to look at your Plex logs and find something that would explain what is going on.
- pauls898AspirantYes Thanks, it all started to go wrong after I received an update for Plex? From then on every time I run Plex using my Panasonic 3DTV it just "Cooks" my NAS CPU, you can watch the temperature suddenly rise from a normal operation level of about 51 deg C to over 70 deg C in matter of seconds and the app then falls over :-(. If I steam to my iPhone yes it has to do some transcoding and the temp does rise slightly to about 60 deg C but no higher and everything is fine :-)
The really strange thing is if I use my DLNA enabled BluRay player as the client that works fine too as no transcoding is taking place and Plex is using the Generic Profile here? There's something strange happening with this Panasonic Viera 3DTV Profile to make it "COOK" my CPU, because before this update everything worked perfectly fine so I don't know what's going on or if anything in that Profile has been changed? If any other users can comment here I'd be glad to hear? Thanks - pauls898AspirantOk hears my findings? I don't know what's going on so maybe you could advise me on what I have discovered?
I have completely removed Plex app completely from my NAS Drive system.
I then installed the older version, I set up a small folder of music videos as a test as I didn't want to wait while it scans in over 1000!
I enabled my DLNA Server, tried the TV and it WORKED!!! What I noticed on the Media Server screen on the TV was it tells me that the Video I'm selecting from the list on the media server is a MP4 format which is correct and everything play as per normal :-)
Now here's the strange thing? I then log onto plex server to Connect it up, give me two green tick and says successfully connected to server.
Then I go back to TV and try it again, the first time I notice that the DLNA service is now missing? So I go back to plex and the tick has gone from the Enable DLNA Server ? So I re-check it and save the changes
Then I go back to TV again select the same Video which played moments earlier and the TV tell me now it's format is VIDEO and guess what it's broken??? I get a "Please Wait" then stuttering playback starts after about 6 seconds?
So what is happening when I connect my Plex to the server and it somehow chances the format of my videos from MP4 to VIDEO and hence the TV doesn't like it?
Another observation was if I do a clean install of the current version that won't work at all???
With the older version installed I have no "Remove" option, so to enable me to remove it, I have to upgrade it to the current version and then the "Remove" option has returned?
So I'm now quite confused as to what to do next? and I've also lost ALL my libraries and there's no point me re-building them till I can get to the bottom as to what's going on?
Something changes once I connect to the Plex server to change this format option from MP4 to VIDEO?
Any ideas???? Please!! - mdgm-ntgrNETGEAR Employee RetiredNot sure on this. Hopefully someone on the Plex forums can help with this.
- btaroliProdigyIf your goal is to completely start from scratch with PLEX, you might want to take a peek around after removing the app from Frontview. As I recall, the PLEX package has a habit of leaving bits of itself around... to avoid people losing their media libraries. But, yes, I'd strongly suggest posting in the plex.tv forums about this.
- pauls898AspirantHi Could you explain what "Front View" is and how I use it? I use PC's and I'm not a Linux person, so all this is new to me?
I did check that after removing Plex that the data\app folder where it goes was completely empty.
It's fine after a fresh re-install, but as soon as I connect to Plex server that's when it screws things up for me? - StephenBGuru - Experienced User"frontview" is the admin web interface in the RN314. (https:/nasname/admin)
- pauls898AspirantOh thanks I've been in there before I just use the IP Address of ReadyNAS and admin and Password, but you get this RED Certificate error come up which I don't think you can do anything about? I didn't know it was called Front View though, but I've heard it mentioned before?
Thanks - mdgm-ntgrNETGEAR Employee RetiredWhat web browser do you use?
I always use IE11.00
I have Chrome and Fire Fox installed on my PC but I prefer Internet Explore TBH.
