otudlaf
Dec 10, 2012Aspirant
4.1.10 password won't work
After I upgraded to 4.1.10 on the NV+ I can't get into RAIDiator. Keeps asking for my control panel password. I've tried everything including netgear1, infrant1 and original passwords I set up. Not...
Dec 10, 2012Guru - Experienced User
If ethernet works, there is probably no need for an OS reinstall.
WiFi can get if the way if you are using RAIDar - that is because RAIDar uses broadcast packets to find the NAS, and some wifi routers won't forward broadcast packets over WiFi.
However, it should work fine if you access Frontview directly from your browser.
