Nasinator
Oct 06, 2012Aspirant
4.1.7 vs 4.1.10 on NV+ (V1)
I've been on 4.1.7 for a while now, it's been rock solid for me from a stability and performance standpoint. I've stayed away from 4.1.8 which had known performance issues that I've well documented he...
maxblack
Oct 09, 2012Aspirant
Nasinator wrote: If I recall 4.1.8 + fixed the time machine protocol for 10.7 (Not sure about 10.8 ). 4.1.9 fixed some AFP performance issues I believe. AFAIK though CIFs works well as far as Macs are concerned in all versions but 4.1.8. 4.1.8 had huge performance issuses in reads across the board and should be avoided if possible.
Thanks for that. Well I don't have a Mac yet, though when I do it will run Mountain Lion, so I'll just sit tight then and see if 4.1.10 gets improved-upon further before updating.
