bartw
May 02, 2012Aspirant
4.2.20 : Volume expansion will not work beyond 16 TB...
Can someone explain to me what that means or give us more details ...
Jan 04, 2013Guru - Experienced User
Volume expansion cannot cross the 16 TiB boundary - the linux expansion tools fail because the block addresses aren't correctly expanded from 32 bits to 64. That limitation is listed in several places in the forum, and is also a limitation listed in the release notes.
Amien wrote:
tranas:/var/log/frontview# resize2fs -pf /dev/c/c
resize2fs 1.42.3 (14-May-2012)
Filesystem at /dev/c/c is mounted on /c; on-line resizing required
old_desc_blocks = 1045, new_desc_blocks = 1394
resize2fs: Permission denied to resize filesystem
dmesg
do EXT4_IOC_RESIZE_FS
EXT4-fs warning (device dm-0): ext4_resize_fs:1675: No reserved GDT
blocks, can'
can this be fixed. anyone knows what is causing this?
If that is what is happening to you, the only way to overcome it is to do a factory reset with all disks in place - which requires all data and the configuration to be restored from backup.
On the other hand, if you already had a volume size that was > 16 TiB then it should have expanded (though the 8 TiB growth limit from the starting point still applies).
