laszlog1
Jul 14, 2012Aspirant
4.2.21, Samsung TV and DLNA
Hi, I recently upgraded my ReadyNAS Pioneer Pro NAS (x86) to version 4.2.21 of the firmware/OS, but I get what can be described as a beaconing issue... Every few minutes the Samsung TV 46"displays...
laszlog1
Jul 15, 2012Aspirant
You are correct -i patched the current version 1.0.25
Here is initrd.log
Here is upnp-av.log:
Here is initrd.log
[2010/04/24 22:21:53] Factory default initiated by button!
[2010/04/24 22:26:39] Updated from RAIDiator to 4.2.9.
[2010/08/19 21:14:41] Updated from RAIDiator 4.2.9 to 4.2.13.
[2010/11/23 16:02:19] Updated from RAIDiator 4.2.13 to 4.2.15.
[2012/01/21 05:15:29] Updated from RAIDiator 4.2.15 to 4.2.19.
[2012/04/28 02:40:11] Updated from RAIDiator 4.2.19 to 4.2.20.
[2012/07/06 11:48:41] Updated from RAIDiator 4.2.20 to 4.2.21.
[2012/07/11 21:47:19] OS version mismatch [1338489604 != 1314659067]
[2012/07/11 21:47:36] Updated from RAIDiator 4.2.21 to 4.2.19.
[2012/07/11 21:57:16] Updated from RAIDiator 4.2.19 to 4.2.21.
[2012/07/13 22:11:02] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2012/07/13 22:11:02] minidlna.c:990: warn: HTTP listening on port 8200
[2012/07/13 22:11:05] upnpsoap.c:1691: warn: SoapMethod: Unknown: RegisterDevice
[2012/07/13 22:11:05] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
[2012/07/13 22:11:13] minidlna.c:153: warn: received signal 15, good-bye
[2012/07/13 22:11:14] minidlna.c:881: warn: Starting ReadyDLNA version 1.0.25.
[2012/07/13 22:11:14] minidlna.c:990: warn: HTTP listening on port 8200
[2012/07/13 22:11:15] upnpsoap.c:1691: warn: SoapMethod: Unknown: RegisterDevice
[2012/07/13 22:11:15] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
[2012/07/13 22:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/13 22:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/13 22:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/13 23:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/13 23:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
Trimmed to fit ...
[2012/07/14 04:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 04:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 05:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 05:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 05:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 05:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 06:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 06:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 06:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 06:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 07:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 07:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 07:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 07:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 08:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 08:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 08:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 08:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 09:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 09:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 09:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 09:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 10:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 10:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 10:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 10:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 11:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 11:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 11:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 11:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 12:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 12:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 12:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 12:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 13:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 13:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 13:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 13:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 14:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 14:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 14:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 14:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 15:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 15:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 15:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 15:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 16:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 16:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 16:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 16:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 17:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 17:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 17:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 17:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 18:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 18:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 18:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 18:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 19:11:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 19:26:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 19:41:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
[2012/07/14 19:42:00] upnpsoap.c:1691: warn: SoapMethod: Unknown: RegisterDevice
[2012/07/14 19:42:00] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
[2012/07/14 19:56:14] minissdp.c:335: error: sendto(udp_notify=14, 5.172.185.148): No such device
